Running FlexC and CentralSW/AUTH same WLC
ajc
Level 11
Level 11
Even though I tested in the lab and looks like it works. I would like feedback about this combined configuration on the same WLC from the experts in the forum.
thanks
Scott Fella
FlexConnect with central switching and central authentication works and its the same as local mode, except you have the ap's in flexconnect. I don't see any issue with this, some organizations would do this because they had 2504WLC's and was worried with the throughput. Now if you are doing this over the WAN, you will need to make sure you have enough bandwidth for all the traffic.
-Scott
