sensor connected to mesh access point
suthomas1
Level 7
Level 7
A 1552E has a temperature gauge sensor connected to its power over ethernet port. the port status shows line protocol as down.
The cable from 1552 to the sensor has been changed twice.
We can see the 1552E gig1 interface is at 1000full duplex.
Is there any chance the speed is causing the problem here. it seems the 1552E doesnt allow to set different speed & remains on 1000.
Please help with inputs!
Amjad Abdullah
Where the sensor is connected? to "PoE in" or to "PoE out" port?
You can set the duplex and speed statically of the AP from the controller's CLI. use the following command:
config ap ethernet duplex speed AP_NAME
If you want to set the speed to 100 use for example:
config ap ethernet duplex full speed 100 AP_NAME
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Amjad
That works. Thank You!
