Setting up Guest wifi in Enterprise environment
saboodi
Hello All,
I'm looking to setting up secure Guest Wifi to the Enterprise environment, any suggestions?
Mark Elsen
 - There are numerous cisco documentation resources about that subject. Relevant googling will guide you.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
here is some guidance document for your reference :
https://community.cisco.com/kxiwq67737/attachments/kxiwq67737/4356-docs-srcug/1/1/89461-BYOD-Advanced%20Guest%20Wireless%20Access.pdf
BB
Francesco Molino
There're multiple documentations on Cisco website like this one : https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/70937-guest-internal-wlan.html
You also have lots of videos on youtube on Lab Minutes channel for example.
The WLC is able to provide a guest portal natively.
But the real question is what kind of guest access you want to provide? Do you want multiple portals,... ?
Because you can use Cisco ISE for guest and leverage it to do BYOD for some "privileged" guests as well.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
