Setting up wireless LAN controller
afath
Community Member
hi,
How to set up wireless LAN controller and what and all minimum parameters need to configure it ? what and all additional device required for it ?.As I planned to run 20 AP in a small compound with LAN controller.
please help me find the same
Thanks for your time
afmk
2 Accepted Solutions
Leo Laohoo
Like Leo mentioned, the config guides will explain in detail what is a available in the code version and you really need to reference that. Here is an old doc with very basics of setting up a wlc.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
-Scott
Leo Laohoo
-Scott
