Slow WLAN throughput using 877W
acraick
have a new 877w wireless router that has in inbuild routed wireless access point (G only). I am connected to it at 54Mbps and the signal strength says Excellent.
The problem being when i download from the Internet via the ADSL2+ Connection and from a Computer on the LAN segment i only get around 2Mbps.
I have also tested the speed via internet based speed checkers and by running leech ftp from the wireless laptop to an FTP server on the LAN side PC.
I know also when i connect the laptop directly to the same LAN i get at least 10Mbps from the FTP server so i know it isn't a bottleneck with the server itself.
Done so far to test:
Disabled all 2.4Mhz phones and bluetooth.
I have checked in the wireless GUI (SDM) and looked at the interface on the router which both tell me I am actually getting around 16Mbps of outgoing traffic (average over 5 minutes) even though i'm clearly not.
This also tells me that i am connecting at 54Mbps.
Any idea's where the problems coming from ?
If anyone else has this router and has better performance i'd love to have a look at your config and see if there's anything i may have configured wrong. My clean config is attached.
jsivulka
Level 10
Level 10
