smartnet for mobility express conversion?
Martin Obermueller
Community Member
hi there,
is a special smartnet (-K9C) required to access CAPWAP to ME conversion files?
Or can i get a CAPWAP AP with normal smartnet and still download the ME conversion firmware?
AIR-AP1852I-E-K9    (not "K9C“)
thanks,
martin
Scott Fella
Should be the same. So you should be able to download either.  If not just open a TAC case and they can probably publish the code for you.
-Scott
-Scott
