Spectrum Expert - USB or Express Card
The Spectrum Expert is a great tool but the problem is to find a notebook with a PC-Card / PCMCIA  slot.
I know that there are adapters available for EC to PC-Card but I think this is not a solution for customers.
I didn't find any information on the Cisco website about an alternative.
Question: When will be a Spectrum Expert Card available with USB or EC connector?
Well from what I have gathered, they are not going to be making any usb, etc in the future.  For portable solutions, you need to look at 3rd party.  That is what I use and many of my clients with no issues at all.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
iilyinas
Level 3
Level 3
hi, Carsten,
It's not exactly the thing you were asked for, but anyway it may help: you can use as a source one of your Cisco AP.
HTH,
Cheers, Irina
Scott Fella
There have been discussions about this a while back and from what I know, there is no future plan for this product. You may want to look at other 3rd party spectrum analyzer's that are USB.
-Scott
Hi Irina and Scott,
I know the AP SE-Connect feature but we need a portable solution.
Cisco should think about a USB or Express Card solution.
The APs are working with the Spectrum Expert and it will be hard to explain to a customer that he should use a 3rd party solution to get a mobile solution.
Thanks and best regards,
Carsten
Scott
-Scott
