SSID Configuration Issue
Jathees
Community Member
Solution Details :
Requirement:
When the student connecting from the Staff SSID, the user cant connected that SSID.
When the Staff connecting from the Student SSID, the user cant connected that SSID.
Issue:
When the Student connecting from the staff SSID, the user will receive the IP from Management VLAN of the AP
When the Staff connecting from the Student SSID, the user will receive the IP from Management VLAN of the AP
So, you want us to do your homework?
Ok, the problem is not related to Meraki. It's all on the RADIUS server.
When the request comes in you need to compare the SSID to the user account. If it's a student and the SSID is "Staff", send an access reject. Same if it is Staff-member connecting to the "Student" SSID.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
aleabrahao
Meraki Community All-Star
It's normal, nowadays people don't like to think much. It's more easier let the others do their work.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Philip D'Ath
The question also seems to be hinting at IP address allocation. You would use separate VLANs for the staff and students.
