SSID not broadcasting
martnord05
Community Member
Hi!
Setup: WLC 4402, IOS 5.0.148.0, eight 1131 APs.
I have a serious problem with a simple thing. I'm setting up a new SSID and I can only get it to work with no security at all. When I apply WPA/PSK the SSID isnt broadcasting. I already have a Voice (WEP) and Guest WLAN (Web auth) working but when I want to add a third it wount work. Any ideas would be much appreciated.
/Martin
andrew.prince
Level 11
Level 11
Martin,
Try following the below guide:-
http://www.cisco.com/en/US/customer/products/ps6366/products_configuration_example09186a008095382f.shtml
but just using local authentication
HTH>
sebastiaannoppe
Avoid version 5.0, its full of bugs.
I updated to release 5.1.151 and it worked like a charm. But then again, there may be other bad things happening with that one...
