SSID QUESTION
mshelton1
Community Member
When you changed a SSID does it requirer you to reboot your AP so it will broadcast it.
Sent from Cisco Technical Support Android App
Scott Fella
No it doesn't.  Enabling the braodcast will only glitch the WLAN SSID and not require you to reboot the ap nor will it reboot your ap.  The one thing you need to check is if your using AP Groups, you need to make sure the wlan is configured for that AP Group.
-Scott
