Strange Reassociation behaviour - help on troubleshoot
b.petronio
Level 3
Level 3
Hi there,
I have a production wlc wich has several ssid's working.
In a particular ssid, the wifi clients are bar code readers, using a wpa psk encription/authentication.
My client had bought a new bar code readers, and since then, we are having problems.
I had capture a debug client <mac> and attached here.
I cant find a reason for so much reassociation requests... even for the same AP.
Please give a light in here please.
My Best Regards,
Petrónio
Leo Laohoo
Try this:
Create a new SSID with OPEN authentication.  See if the new bar code reader works.  If it does, then ramp up the security.
Bar Code readers/scanners are notorious for having early to very-early generation of wireless cards in them (the cost of those early models are in their cents) and most of the time 802.11b with data rates of 1 or 2 mbps is required.
Thank You leolaohoo,
I'll try it asap.
Do you detect any strange behaviour on the log ???
I detect a strange shortcut on the flow ...
START -> AUTHCHECK -> 8021X_REQD -> L2AUTHCOMPLETE -> RUN
*apfMsConnTask_0: Sep 23 13:41:06.809: e0:2a:82:68:b3:da 10.120.109.101 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Sep 23 13:41:06.809: e0:2a:82:68:b3:da 10.120.109.101 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_0: Sep 23 13:41:06.809: e0:2a:82:68:b3:da 10.120.109.101 8021X_REQD (3) Plumbed mobile LWAPP rule on AP ac:a0:16:ca:b8:30 vapId 1 apVapId 1
*Dot1x_NW_MsgTask_2: Sep 23 13:41:06.878: e0:2a:82:68:b3:da 10.120.109.101 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Sep 23 13:41:06.878: e0:2a:82:68:b3:da 10.120.109.101 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
From "Policy Enforcement Module (PEM)" Figure, in "http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a008091b08b.shtml" i see it bypass dhcp states.
But nevertheless, if we have "RUN" states, then we could afirm, that " Client has successfully completed the required L2 and L3 policies and can now transmit traffic to the network" . Im i right ?
Petrónio
