Stuck in IP Learn state
Dongyeong Kim
Some end user cannot connect the corporation SSID. I found the bug,  CSCvs03177. I'd like to make sure whether I found the right things or now. Could you help me with this?
Model: 9800-CL Wireless Controller
Version: 17.3.1
Finding: 3 users. Stuck in IP Learn state - IPv4 and IPv6 values are N/A.
2e9e.****.**** N/A N/A AP-Name SSID-Name 1 IP Learn 11ax(5) Un-Classified Device Local
Logs: attached.
Wifi adapter of end users' laptop was updated.
Thank you,
Dongyeong (DY)
Sandeep Choudhary
did you disable central DHCP and/or disable DHCP required ? if not then try it
Dont forget to rate helpful posts
Leo Laohoo
Upgrade the WLC firmware first.
