taking too long to connect to wifi
zmk
My problem is the clients taking too long to connect the SSID in my wifi network.
In the WLC, I saw the following log message.
%LWAPP-3-INVALID_AID2: spam_api.c:1791 Association identifier 2 for client XX;XX:XX:XX:XX is already in use by XX:XX:XX:XX:XX for AP XX:XX:XX:XX:XX slot 0 vap 1
Anybody can explain me that are those logs showing the cause of the problems or not?
7 Replies 7
Leo Laohoo
Have you tried with PSK or OPEN authentication?
It's currently using PSK, haven't try open authentication yet.
Sandeep Choudhary
are your AP in flexconnect or local mode ?
which software version are you running on WLC ?
APs are in flexconnect mode and software version of WLC is 8.5.105.0
Sandeep Choudhary
8.5.105.0 image is alredy deffered from cisco.
Try to upgrade to a satable software version
either go for 8.5.135.0 or 8.5.140.0
Dont forget to rate helpful posts
Thanks for your advice.
So just to be sure, the reason of wifi taking too long to connect is this bug?
In some content, some say it's CSCtn52995 bug.
yes may be ...
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtn52995/?rfs=iqvredhttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCve81269/?rfs=iqvred
Just try to update to new software and check again..
