tpc
wyfy-2015
Level 3
Level 3
If I set the tpc value maximum 17 and  minimum 11 . An I phone's maximum power is 14 dbm .
Let's assume that the iphone is at the edge of the cell
So Even in this case Iphone can hear the AP , but the AP may not hear the iphone
Please correct me if I am wrong
Hi @wyfy-2015
 If you set the AP between 11 and 17 and client at 14 this means that the client will be between 11 and 17 right?
But the problem your are describing is quite common. AP has higher power than clients and often this can happen.
 That's why when you are going to perform a site survey set the AP power to the same value of client power or even lower, so that you make sure that client's will always be heard by AP.
-If I helped you somehow, please, rate it as useful.-
