Trashed Firmware on WLC 2006
jeffreyhammond
I was doing an update on a 2006 WLC and after i uploaded the firmware and everything finished fine i saved the config and rebooted. Now i will not boot up and I cannot get into the Console port.
Does anyone know the type of cable needed and the serial port settings to get into the CLI via the serial port?
Additionally is there any way to fix this without RMAing the device?
brispin
The following document will clearly explain you how to connect the WLC through console port.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml#basic
Aso, this document explains the software upgrade procedure
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
