Unable to discover AP350 using WLSE
dinux
I am using WLSE 1.3 and using AP350 12.01T. It always give me snmp unreachable. unable to read cdp cache. What can be the problem. I put the seed device as the switch that is connected to the AP and the device credential is the AP that I am going to discovered. Any other settings?
Thanks.
derwin
Level 5
Level 5
Have you got SNMP correctly configured on the AP ?? you using the correct snmp community names
