09-21-2012 02:55 AM - edited 07-03-2021 10:41 PM
We are looking to deploy an indoor mesh deployment in an area where radar might be an issue.
I know that when using 1500 series APs you cannot choose UNII-1 channels even if they are deployed indoors.
My question is if you can use a UNII-1 backhaul with indoor APs (3600 series for example) in an indoor mesh deployment.
FYI we are in Europe.
Justin
Solved! Go to Solution.
09-24-2012 10:31 AM
yes, it would appear that you can select UNII-1 with a indoor ap. See below. I hope this helps.
__________________________________________________________________________________________
09-21-2012 07:29 AM
If UNII-1 is legal for indoor access points, it would be the same for other indoor APs in bridge mode. Outdoor APs ate different due to their EIRP.
09-24-2012 12:32 AM
Thanks for the reply but that was not really what I was trying to know.
I know that UNII-1 is legal for indoor use here in Europe. My question is can an indoor AP, configured to be a mesh AP be configured to use UNII-1 channels for the backhaul.
The 1500 series cannot, even if they are being used indoor and the EIRP has not been exceeded. It is just not an option. So..I was wondering if it was the same for indoor APs that are configured to mesh APs.
Justin
09-24-2012 10:31 AM
09-24-2012 10:03 PM
Thanks. This helps alot.
