Updated controller but not showing right version
polleyjb01
I just updated my 4404 controller with 7.0.116.0.
After I rebooted and check the version number on the monitor page, it tells me its still version
7.0.98.0. The weird thing is, is that the Emergency Image Version is what changed to version 7.0.116.0.
George Stefanick
Check your swapped image: Check the WLC part towards the bottom. This will be a place to start ..
Iblogged about this a bit ago ..
http://www.my80211.com/cisco-wlc-cli-commands/
Controller and Access Point Image Swap
Access Point - Swapping the image can done by a single access point or by all access points
(WiSM-slot8-2) >config ap image swap all
(WiSM-slot8-2) >show ap image all
Total number of APs.............................. 2
Number of APs
Initiated............................................ 0
Predownloading.................................. 0
Completed predownloading.................. 2
Not Supported.................................... 0
Failed to Predownload.......................... 0
AP Name            Primary Image  Backup Image   Status          Version        Next Retry Time  Retry
TEST1                        7.0.98.0            6.0.196.159    Complete        7.0.98.0       NA               NA
TEST2                        7.0.98.0            6.0.196.159    Complete        7.0.98.0       NA               NA
Controller- Swapping the image on the controller
(WiSM-slot8-2) >config boot primary (backup)
(WiSM-slot8-2) >show boot
Primary Boot Image............................... Code 7.0.98.0 (active)
Backup Boot Image................................ Code 6.0.196.159
Stephen Rodriguez
you should also be able to issue the command
show boot
to see what the primary and backup image on the WLC is.
What file did you load to the WLC?  If it had the -ER at the end, then it is only the ER/bootloader update.
The file should read AIR-WLC4400-K9-7_0_116_0.aes, to be the actual code for the WLC.
HTH,
Steve
Please remember to rate helpful posts or to mark the quesiton as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
