Upgrade code for WLC5508
wfqk
Level 7
Level 7
Hi, WLC 5508 code version is 8.0.152.2, do we need to upgrade the code? Thank you
3 Accepted Solutions
Mark Elsen
 - It is always recommended to use the latest gold-starred release for your 5508. Sometimes newer ap-models may require later code too.  Usually newer version fixes a lot of bugs.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Seb Rupik
Hi there,
The release you are using is one of the suggested releases for the platform. You will need to look at the release notes for the other three suggested releases and weigh up the new software features each one brings against its compatibility with older Access-Point models.
cheers,
Seb.
Haydn Andrews
For you reference the TAC recommended software versions is here:
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
You will need to confirm software compatibility with your WLC and APs:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Recommend to bookmark both of these for future reference when deciding on an upgrade.
Regarding should you upgrade, whilst it is always recommended to upgrade to one of the latest versions you need to also determine:
  • Is there a new feature set you require that current version does not support
  • are you requiring new version to support newer APs
  • are you hitting a bug requiring you to upgrade
  • will you APs/ WLC support the upgrade
*****Help out other by using the rating system and marking answered questions as "Answered"*****
6 Replies 6
Mark Elsen
 M.
Seb Rupik
Hi there,
cheers,
Seb.
Thank you so much for your reply. I can see there are four latest version, 8.5- 8.2- 8.3- and 8.0-. My version 8.0- is latest one. What is main difference among them?
A quick scan of the release notes shows no new major software features, but some resolved caveats. Probably the biggest headline which may effect your deployment is the dropping of support for older APs:
  • Cisco Aironet 1560 Series Access Points
  • Cisco Aironet 1570 Series Access Points
  • Cisco Industrial Wireless 3700 Series Access Points
cheers,
Seb.
Thank you!
Haydn Andrews
