Using more then one interface
jjabson
Level 4
Level 4
Would there be instances where a user would use both physical interfaces on an MR device? If so, would they ever use both to separate traffic between SSIDs?
Thanks in advance!
Philip D'Ath
Meraki Community All-Star
Only the MR53 and above have two interfaces, and they are only used to increase the bandwidth to the AP using channelling/bonding.
https://documentation.meraki.com/MR/Installation_Guides/MR52%2F%2F53_Installation_Guide#Ethernet_Ports
They can not be used to separate traffic between SSIDs.
Philip D'Ath
@Philip D'Ath
Thank you!
