Virtual Wireless Controller HA
Wesoley
Level 3
Level 3
I am doing a deployment for a customer and just wanted to find out if you can setup the vWLC large deployment option in high availability between 2 data centers. I know you can put the IPs of the controllers on the APs, but was wondering if there is a way to sync between the virtual controllers.
There is no sync without SSO. Everything is a manual configuration on both controllers.  You can look at using Prime Infrastructure to push out configs, but I don't think that is what you want to do.
-Scott
-Scott
Scott Fella
The vWLC doesn't support SSO so you would have to use N+1.  There is no sync that will happen without SSO support.
-Scott
-Scott
I know that it does not support SSO, but is there any way to sync the config between both? Like if I create a new SSID, will it sync to the secondary?
-Scott
-Scott
Thanks for the feedback. I am using prime to push out configs but to other devices.
