VoWLAN with 7925G and FlexConnect - What are current recommendations and Experiences
lmslattery
Hi All,
From reading current config guides etc I understand that VoWLAN should be fine with FlexConnect if APs at a given FlexConnect enabled site are in a common FlexConnect Group
I also seen articles including the following that recommend against the use of FlexConnect for relianble voice.Noting this article is now a couple of tears old.
https://supportforums.cisco.com/document/112171/how-get-your-792x-wireless-phones-performing-reliably
What is the current postion on FlexConnect with Voice and what are peoples experiences ?
I have a customer with a few remote sites each with under 10 APs that I'm considering FlexConnect of their central controller  howver voice is required these sites.
Many Thanks,
Leon
Freerk Terpstra
Level 7
Level 7
If you do your survey right, tune RRM, have all the phones staticly connected on the 802.11a only with the latest software release and QoS is end-to-end in place, you will be fine.
Carefully choose your AirOS release, I did have some issues with one-way audio before the 7.4.121 release. In one deployment I even used WPA2 AES with PSK's but did not experienced issues do to bug CSCtt38270.
Rasika Nayanajith
Here is the latest 7925G deployment guide [1.4(5)SR1 Release)].
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf
If you follow these best practices & use your branch office AP in FlexConnect AP group & CCKM enable on the WLAN you should be fine. In FexConect mode still layer 3 roaming of local switched WLAN is not supported. Below is the latest 8.0 WLC config guide with respect to FlexConnect
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_010001000.html
Rasika
**** Pls rate all useful responses ****
