Vxworks and IOS version snmp traps problem.
alomar818
The AP works with Vxworks version can traps client associate and authenticate informations with client's MAC address and IP address.But when we upgrade the AP from Vxworks to IOS version the snmp traps does not include the information above.Have any command on IOS version I need config or IOS version doen not support the authentication traps.Does anyone know this problem? Thanks for your answer a lots.
a-vazquez
Level 6
Level 6
When you use an earlier Cisco IOS Software Release, not all options are supported. When you use a later version than 12.1(3)T, additional [notification-type] options could be supported. You can find a current list of all supported Cisco IOS Software Simple Network Management Protocol (SNMP) trap Object Identifiers (OIDs) in this document.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a05.shtml
