WCS and WLC Reporting
mjohnson1914
Hello All,
Does anyone know if there is a way to get the WCS or WLC to report if a change had been made via syslog or snmp?
Also, is there anything specific that has to be configured in the WCS to send emails of traps or alarms? I see where there are places you can enter emails but I am not sure if that is all that is required for the WCS to send the report to that particular email address.
Any configuration examples or details would be great.
tstanik
Level 5
Level 5
On the controller, the WLC can be setup to send messages to a syslog server you may need to specify on the GUI, the level of the messages you want sent for rogue detection, you may need to specify software errors. Also, via WCS, you can have it send emails on the rogue traps / messages. A 3rd method is to setup snmp if you have something like hp open view. the mibs are at the link below, depending upon which image you have.
