WCS - Copy and Replace AP
nathanjscott
Level 4
Level 4
Under Configuration/Access Points
The boxes to select an AP are greyed out.
This is preventing my ability to Copy and Replace when I choose the drop down in the upper right hand corner. Is there a way around this?
I'm running WCS code 4.1.83.0
I've also seen this on other codes, I believe its universal.
geoffarmstrong
Frequent Visitor
Frequent Visitor
You are only able to click this box if the AP is offline from what I have tested. Not sure if it is meant to be like this or not. Have you spoke to TAC about it?
