WCS Location addition problems
jaime.pedraza
Level 4
Level 4
I've recently upgraded to the last versions WCS 4.2.62.0 and Location 3.1.35.0. According to the compatibility matrix, the versions are compatible.
When I try to add the location on the WCS, I'm having the following error: "No response from Location Server. It may be unreachable, or connectitity credentials are incorrect"
I tested the connectivity and the services, and are ok. I'm using the default config:
server-name: loc-server
ip add: 10.0.0.100
user: admin
pass:admin
port:8001
https: disable
Does anyone know what could be happening?
Thanks in advance
ericgarnel
Level 11
Level 11
Have you tried restarting or rebooting the LOC server since the upgrade?
several times. Today I found, the admin user was not created, I manually created it, but it didn't work, I assume this user has to have some permissions.
Is there any way to restart de location to the default config?
Thx
