WCS WLAN template interface fields
danhosking
Level 3
Level 3
I am currently working on WCS. I was wondering if anyone would be able to give me clarification on the following when creating a WLAN template on a WCS.
Under the General Tab -
- Interface
- Egress Interface
- Ingress Interface
carenas123
Level 11
Level 11
In WCS software release 4.0.96.0 and later releases, you can configure multiple WLANs with the same SSID. This feature enables you to assign different Layer 2 security policies within the same wireless LAN. To distinguish among WLANs with the same SSID, you need to create a unique profile name for each WLAN.
For the further description for Configuring WLAN Templates following URL may help you
http://www.cisco.com/en/US/docs/wireless/wcs/4.1/configuration/guide/wcstemp.html#wp1071033
carenas123
Level 11
Level 11
