wcs
diro
Level 6
Level 6
in the wcs is the heatmap based upon rf-prediction or measured rf values?
b.hsu
Level 11
Level 11
If you are using WCS Location, WCS compares the RSSI signal strength from two or more access points to find the most probable location of the client and places a small laptop icon at its most likely location. If you are using WCS Base, WCS relies on the RSSI signal strength from the client and places a small laptop icon next to the access point that receives the strongest RSSI signal from the client.Refer the following URL for more info
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a008059ca02.html
