Web Authentication and Proxy
recep.sefer
Level 4
Level 4
I have WLC 5508
I am using web authentication
If I dont use proxy server in my internet explorer, no problem, web auth. page comes ...
but
If I use proxy web authentication page does not come
Proxy server is located on DMZ with real IP address
Please help
tfraij
please note that WEB-auth does not work with proxy.
if you have proxy , then go to yoru browser and add the virtual interface IP addresses to the excluded list of proxy.
Kind regards
Talal
please rate answers that you find useful , and mark as answered - when it is 🙂 - so others can find it easily
Stephen Rodriguez
there is a command that can be run on the cli of the WLC to add another port to listen on, if your proxy isn't. Configured to listen on port 80.
Config web-auth port IIRC is the command
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
