Web based statistics errors X IOS statistics errors
muca
Level 5
Level 5
When I issue a show int dot11 command I don't see crc errors and others but using the web based tool I see a lot of crc errors, header crc etc. I would like to know if the web based management tool is a reliable tool? I have already cleaned the log but it is increasing every minute.
smahbub
Level 11
Level 11
For the counters to be exactly identical in both the CLI and the web page, the radio needs to be shutdown first. Otherwise the statistics numbers keep on increasing depending on the traffic.
Smahbub, a reload would be sufficient or do I need to turn off the radio?
