WGB350 issue
atassone
Community Member
I've a WGB350 associated (no encryption at the moment) to an AP350 :
host ------ WGB350 - - - - - AP350 ------ router
x.x.x.99 x.x.x.250 x.x.x.217 x.x.x.1
The role of the AP is "root", and the WGB it's seen as a "repeater".
I didn't configure any route neither on the WGB nor on the AP.
From the router I can ping the WGB and vice versa, but the host is unreacheable, and so is the AP and the router from the host.
What's the mistake?
TIA.
Antonio
kmarrero
Level 8
Level 8
Try upgrading the WGB to the latest firmware and see if that fixes your issue. You may even reset the WGB back to the factory settings and reconfigure it just to make sure the configuration is correct.
kmarrero
Level 8
Level 8
