Whatsapp causing Issues to random users
usmansa.1
Community Member
I have 3 SSIDs configured [ Staff, Student and Guest]. I have applied web filtering on Student and Guest SSIDs as below but Staff users are also facing issues on browsing and sending messaged on Whatsapp. There is no restriction on SSID Staff. Not all users but random users.
13 Replies 13
ConnorL1
Meraki Employee All-Star
With WhatsApp being owned by Facebook, it's likely the "Social Web & Photo sharing" rule that's causing the issue as one of the services in that group is Facebook. Try removing it.
LCHD1
Community Member
We are experiencing the same issue on our organization. As mentioned by usmanSa there is NO RULES in place for the SSIDs we are testing with. We tried both Meraki DHCP NAT mode and also Local LAN DHCP mode and the issue is the same on both scenarios. messages don't get delivered, and both audio and video calls ring on both ends but sessions cannot be established - status of the calls stay in the "Connecting" phase with no media flowing in either way.
Provided this post was initiated a few months already, are there any plans from the Cisco Meraki team to resolve this problem? It is a big issue nowadays that Whatsapp is widely used.
ConnorL1
I use Meraki kit at home and I've never had an issue with WhatsApp, nor is there any Meraki-wide problem with using WhatsApp, every network is different.
I would advise checking your firewall settings and contacting Meraki Support should you continue to experience issues.
LCHD1
Community Member
I use at home as well and noticing for Meraki NATted SSIDs it is blocking traffic - running some tests with an SSID with external DHCP and using a specific VLAN ID seems to be conflicting as well. Firewall wise thee is no much to check in a home router but compared to another wireless solution - including the same home router wireless service - I know Meraki is causing issues. I have engaged Meraki support for assistance but unfortunately their support is not as effective as Cisco TAC..I was hoping this post would bring Meraki expertise to the table as I don't think I am the only customer experiencing issues with this kind of traffic.
ConnorL1
Meraki Support has visibility into your network and configuration so they're best placed to assist with specific incidents or issues.
If you DM me your case number I can take a look, but without sharing the troubleshooting steps you've taken or firewall/network configuration here, resolving the issue is a needle in a haystack.
LCHD1
Community Member
I have DM you the case as requested. If you need additional information about the case let me know and I can provide it all to you.
LCHD1
Community Member
Seems I cannot reply to your last private message. We have 3 scenarios indeed:
No NAT used, no VLAN ID. WhatsApp seems to work fine on it.
No NAT used, VLAN ID in use. WhatsApp not working properly.
NAT used for Guest SSID. WhatsApp not working properly.
Waiting to hear back from engineer assigned...even though according to his reply NAT seems to be well known for causing issues with WhatsApp - not sure if you had the chance to read the case notes about this.
LCHD1
Community Member
Case opened is not moving and the issue persists. Would it be possible to get your assistance in having my Meraki case escalated or transferred to someone that can actually assist?
ConnorL1
Hi @LCHD1, I recommend calling in if you require immediate assistance. I'll respond on the case for you now.
As per your response above, the issue appears to be related to your firewall and filtering or firewall rules on the configured VLAN are blocking Whatsapp.
LCHD1
Community Member
Cosmicus
Community Member
I know this thread is a bit old, but I’m curious whether anyone tried switching the SSID from NAT mode to bridge mode just to test if Whatsapp behaves differently. I’ve seen similar quirks disappear once the client gets a clean upstream DHCP lease. If staying in NAT mode is required, has anyone checked whether the home router’s DHCP pool or VLAN tagging might be overlapping with Meraki’s default subnet?
I would collect packet capture on the access point the device and connected to and using the TTL value of a packet you can determine where the packet is being dropped.
Cosmicus
Community Member
I’ve bumped into similar quirks whenever NAT, VLAN tags, and chat apps get mixed together, and it can feel like chasing ghosts. In my case, tweaking DHCP scope isolation and making sure the SSID’s VLAN ID wasn’t clashing with the home router helped a lot. I use the whatsapp business api on one of my test networks, and it behaved fine once I cleaned up the double-NAT and made the tagging consistent.
