why wifi is called half duplex
fb_webuser
Level 6
Level 6
In a tutorial video i have found that wiifi is called half duplex. why it is so called?
Posted by WebUser Poristhan Prince from Cisco Support Community App
Rasika Nayanajith
This is because a wireless client & AP cannot communicate at the same time. If AP transmit then others should listen & If a client transmitt others should listen.
That's why it call half duplex. Watch this video for better understanding how it works (you require to register ciscolive365.com first, it is free)
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=8197&backBtn=true
Rasika
*** Pls rate all useful responses ****
