Wifi 802.11ac dynamic channel width negotiation
iamzain
Let's assume that
AP1 is on channel 40 width 80mhz, AP2 is on channel 48 width 80mhz, It overlaps.
As far as i understand 802.11ac has a functionality which detects width utilization per-frame and falls back to a much lower channel width. If AP1 detects AP2 and vice-versa they can go back to their main 20mhz and they might not overlap if they stay like that.
I never found a standard name for this functionality, there is 'Clear Channel Assessment', aruba calls it 'dynamic per packet negotiation of channel width', there is a lot more.
What i do not understand is how this could not cause issues like interference, for example, if they try to communicate at the same time at 80mhz
Leo Laohoo
Not necessarily.
It is even possible for all APs to be using channel 40 while using 40- or 80 mhz width.  How?  Attenuation.
If those APs cannot even "hear" each other, what is stopping them from re-using the channels?
