Wifi cannot print data but LAN can print. What's wrong?
Ppppp99
I found some trouble about Wifi internet cannot print out data but LAN can print.
I use access point for CISCO WAP-150 and just update version of firmware to 1.1.1.0 on middle last week. but just found trouble on Monday. and for CORE SWITCH i use CISCO SG-200 but no upgrade firmware (current version is Version 1.4.2.4).
First, I disconnect and connect again data can print but after that will happen again.
Please suggest me to check and solve trouble.
---- Update data
after I monitor interface i found this error as below.
what's mean please suggest me.
--- error occured for query on path cluster.stations-aggregated.session (function: data_service, file: /home/sigmund.lou/cisco_tp361_150/ap/broadcom/src/web-ui-framework/data_service.c, line: 481) activator.stations-aggregated.session, timed out. (function: activator_execute_buffer, file: /home/sigmund.lou/cisco_tp361_150/ap/broadcom/src/web-ui-services/activator_query.c, line: 131) ----
Thank you all for support!
ps. sorry for my poor english
Scott Fella
If the issue happened after you upgraded, then it’s best to downgrade to a version that was working.
-Scott
Thank you for your answer. Tonight I will try to downgrade version of AP.
But I have some error as below and sometime AP not obtain IP Address, not show the Computer-name.
[I  turn on DHCP on firewall and reservation DHCP by MAC Address]
luis_cordova
Hi @Ppppp99
Verify that both networks are on the same vlan or, otherwise, that routing between vlan is being performed on a device on your network.
