11-17-2015 02:07 AM - edited 07-05-2021 04:14 AM
Hi Everyone,
Need support, i'm originally an RnS support, anyone who can suggest how to nail down which is the problem on a wifi issue. Customer reports that wifi users always get disconnected. Any suggestion to start the troubleshooting is much appreciated.
Sonny
Solved! Go to Solution.
11-17-2015 02:13 AM
Provide the WLAN info. From WLC:
sh WLAN <I'd >
debug capwap <MAC address >
11-17-2015 02:13 AM
sh WLAN <I'd >
11-17-2015 02:35 AM
Hi Sandeep,
Thanks for this useful info.
I have not got my hands yet on the equipment, but the logs sent by the admins include these logs:
*spamApTask2: Nov 17 13:32:56.592: #LWAPP-3-REPLAY_ERR: spam_lrad.c:37704 The system has received replay error on slot 0, WLAN ID 1, count 1 from AP 58:97:bd:83:7c:20
*spamApTask3: Nov 17 13:31:47.040: #LWAPP-3-REPLAY_ERR: spam_lrad.c:37704 The system has received replay error on slot 0, WLAN ID 1, count 61 from AP e4:aa:5d:19:c8:70
*spamApTask2: Nov 17 13:30:56.606: #LWAPP-3-REPLAY_ERR: spam_lrad.c:37704 The system has received replay error on slot 0, WLAN ID 1, count 2 from AP 58:97:bd:83:7c:20
*spamApTask3: Nov 17 13:29:47.053: #LWAPP-3-REPLAY_ERR: spam_lrad.c:37704 The system has received replay error on slot 0, WLAN ID 1, count 4 from AP e4:aa:5d:19:c8:70
*RRM-CLNT-5_0: Nov 17 13:29:15.093: #RRM-3-RRM_LOGMSG: rrmClientProc.c:691 RRM LOG: Airewave Director: Unable to set channel 0[20] on the on AP E4:AA:5D:19:C8:70(1)
*RRM-CLNT-5_0: Nov 17 13:29:15.093: #RRM-3-RRM_LOGMSG: rrmChanUtils.c:617 RRM LOG: Attempt to set invalid channel 0 on AP E4:AA:5D:19:C8:70(1)
*spamApTask6: Nov 17 13:26:57.122: #LWAPP-3-REPLAY_ERR: spam_lrad.c:37704 The system has received replay error on slot 0, WLAN ID 1, count 5 from AP 58:97:bd:44:ef:70
*spamApTask4: Nov 17 13:26:36.777: #LWAPP-3-REPLAY_ERR: spam_lrad.c:37704 The system has received replay error on slot 0, WLAN ID 1, count 6 from AP 58:97:bd:80:5e:50
Any obvious information I can get from here?
Sonny
11-17-2015 03:03 AM
Not so much info I got from these logs.
I can only say......
1. The first thing I would look at is the WLAN. Makes sure WPA2/AES is the only think checked, not WPA or TKIP. Use either WPA + TKIP or WAP2+ AES.
2. fast-ssid must be enabled...
3. Upgrading the driver on the client is another thing that might help
Dont forget to rate helpful posts
11-30-2015 07:05 PM
We found out the issue. This was because of a universal AP domain/region and settings. Priming required to change this settings. This case was already solved. Thanks everyone!
Please refer to this short documentation:
Priming Requirements
A universal access point can get primed in two ways:
Action taken
One of the Cisco 2702I universal access points will be primed. After the first AP has been successfully manually primed, then the other universal AP in the RF neighborhood can get primed via Automatic Priming.
Manual Priming
Cisco AirProvision uses the geographical location of the smartphone on which it is running, to decide on the regulatory domain for priming the AP.
Automatic Priming
Final AP Status
If the AP is already configured correctly based on the location of the smartphone, it will be verified using the Cisco AirProvision on the smartphone. The Configure and Audit buttons will be disabled with the message 'Universal AP is configured correctly'.
The priming can also be verified with the observed LED light of the access points and their status viewed on the WLC they are connected to.
