Window 8 WiFi problem with Cisco wireless network
Not applicable
Anyone encounter a Windows 8 WiFi authentication problem with Cisco wireless network?
We are using WLC 5508, 7.2.111, and AP 3602i with WPA2.
8 Replies 8
George Stefanick
Hi Eric
Did you do a client debug on the WLC?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
I need to find my debug file and post it later.
This problem occurred with Soney, and Dell models.  Lenovo with Windows 8 factory installed is working fine.
So usually when something like that happen, its usually the driver on the client card. See if there is an updated driver from the manufacture and then test it to see if that fixes it. Also, you alway try to see if it connects with an open connection or not.
-Scott
Won't make any difference as these laptop's wireless NIC cards are different.
Can you try with OPEN authentication.  If the Sony and/or Dell laptop works, then you start cranking up the security and/or encryption settings until you break them.
I'm with Scott here:  It's got to be a wireless NIC card driver.
As what George has stated, post the debug of the failed attempts.
Scott Fella
That code 7.2.111.3 does fix the issues with Windows 8. Might just be an issue with your config maybe. You do need to provide more data like the debug that George requested, but also tell us if all, some, or just one device is having issues, what device and what encryption and authentication method, the show WLAN is another one you should post.
https://supportforums.cisco.com/docs/DOC-27213
-Scott
Yahya Jaber
i would follow these steps.
https://supportforums.cisco.com/docs/DOC-30622
Leo Laohoo
I think you need to upgrade to 7.4.100.0.
Not applicable
As a update, I am upgrading all WLC to 7.2.111.3.
