wired guest network on WLC 5508
Not applicable
Could I setup wired guest Internet connection without layer 3 web authentication and how?
I want guest users access Internet without going through web authentication.
Stephen Rodriguez
Yes you can.
To set it up you create a layer two only VLAN. Them create an interface on the WLC and mark it as a guest LAN. When you create your new WLAN crate it as a Guest LAN, the layer two VLAN you created goes as the ingress interface and whichever interface you want them to get an IP address from.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella
Just to add, if you don't want to use WebAuth for wired guest, why even use the WLC? Your better off using acls.
-Scott
