Wireless 4400
benb12345
Community Member
I have an "AIR-WLC4400-K9-4-0-219-0.aes" and when I disable the "broadcast SSID" and I am not able to connect to the controller?
Can you help
ivillegas
Level 11
Level 11
Make sure the SSID and authentication type match on the client and the controller. Does it work when SSID is broadcast?
yes
