Wireless - 802.1x auth fail
LC.IT
Level 3
Level 3
Hi, let me see if anyone saw a situation like this:
802.1x PEAP MSCHAPv2 authentication using a laptop windows and a smartphone.
The Radius Server is Cisco ISE and it reply the MR AP with a Access-Accept packet.
Cisco ISE and Access Point are connected to the same L2 domain, same subnet and there is not a firewall on that communication.
The Access Point was added on ISE as NAD and there is not logs of problem on ISE side.
I did a packet capture on wired interface of Access Point MR46E and the Access-Accept is delivered but in dashboard I see this error:
"Client 5c:cd:5b:a2:40:ab had a failed connection to SSID Corp on AP POC01 during authentication because the auth server did not respond."
How auth server did not reply if I see the access-accept arriving on AP?
Someone saw this behavior?
Make_IT_Simple
If you guys are not using the new view, please do so and change the radius timeout from the default 2 sec to 10 sec (This is the max value) and it should help with your issue.
https://documentation.meraki.com/MR/Access_Control/MR_Meraki_RADIUS_2.0#Server_Timeout_and_Retry_Count
11 Replies 11
Raphael_L
Meraki Community All-Star
Following this thread.
We do have lots of these , but never had the time to troubleshoot it properly.
Make_IT_Simple
Raphael_L
The default is 1s , and according to Cisco's documentation it seems to be 5s on Cisco's WLC . Strange to see such a big difference between 2 timeouts. I will try to adjust it and monitor the difference in the logs
Raphael_L
I just opened a case regarding that. We are on 27.7.1 and 28.5 and I keep seeing "Client made an 802.1X authentication request to the RADIUS server, but it did not respond."
Upon taking a packet capture we can see the Access-Reject from our Radius server. The request was made in 300-400ms which is below the default timeout.
To be continued...
Raphael_L
Update. It seems that the error is not showing the same description from Wireless -> Health -> Connection log versus Wireless -> Health -> Timeline
In the Timeline page you will see : Client X had a failed connection to SSID Y on AP Z during authentication because the auth server rejected the auth request.
In the Connection Log : Client made an 802.1X authentication request to the RADIUS server, but it did not respond.radius_ip='XX.XX.XX.XX' reason='radius_login_failure' radio='1' vap='0' channel='104' rssi='50'
I know this case is a bit different from yours , but can you check if you are seeing the same log message in the Timeline page and post the results between Timeline and Connection log.
Thanks ,
In my case, the both logs are similiar:
Connection Log==> Client made an 802.1X authentication request to the RADIUS server, but it did not respond.auth_mode='wpa2-802.1x' vlan_id='11' radius_proto='ipv4' radius_ip='172.16.x.x' reason='radius_timeout' radio='1' vap='1' channel='149' rssi='30'
Timeline==> Client 9a:b0:xx:xx:xx:xx had a failed connection to SSID Y on AP Z during authentication because the auth server did not respond.
Raphael_L
Can you do a packet capture and calculate how long does the request take ? First packet to the last one ( Access-Accept ). If it is over 1000ms , it will we flagged as didnt respond.
Yes, I did a capture.
Time from first radius package: 16:04:45,239667
Time from last radius package: 16:04:49,287265
Almost 5 seconds...
Unfortunately I am not able to test now, but I will try to increase the timeout and verify if solve the problem
@RaphletournDid you try increase radius timeout?
Raphael_L
I will be increasing our timeout to 5 seconds , but we don't have currently issues with timeouts.
However you seem to be having issues with it.
LC.IT
Level 3
Level 3
Increase the Radius Timeout solved the problem!
Thank you so much!
To what extend did you increase the Radius Timeout?
Thanks!
