Wireless AP 1260 issue
thembsmoyo26
We are having challenges with our new access points Cisco 1260, it drops connections after a couple of minutes I get the following errors
"Two TKIP Michael MIC failures were detected within 30 seconds on Dot11Radio0 interface. The interface will be put on MIC failure hold state for next 60 seconds."
"Interface Dot11Radio0, Deauthenticating Station Reason: Invalid MIC
21 Replies 21
Amjad Abdullah
This is usually due high interference/noise around.
A good solution is to avoid using TKIP and to use AES.
If your clients all support WPA2-AES then you can take that option. This will save you the headeache of TKIP MIC errors.
Amjad
Rating useful replies is more useful than saying "Thank you"
changed encryption mode to AES-CCM and users are connected and no connections are being dropped, the problem is this is contradicting company global standards on Wireless AP, we have other access point which are working fine with TKIP encryption
please assist in solving this problem without changing encryption mode
George Stefanick
Tkip countermeasure is part of the 802.11 standard. If a client send 2 bad mics in a 60 second period you will see the alert.
Ways to work around this ..
Move to aes and don't use tkip or turn off countermeasure.
Is this ap controlled by a wlc ?
Amjad
Lol I'm a few seconds behind u this morning !
Lol. ya. First time I am quick enough.
i have  tried to isolate the device to avoid any noise or interference but still it drops connections, this access point is managed by a NPS server and users are managed by GPO, so if setting don’t match they fail to connect as such changing to AES hasn’t worked yet as users fail to connect.
i have also tried changing timers and disabling them thus the client hold off time, EAP or MAC reauthentication interval, TKIP MIC failure holdoff time and still its dropping connections
we have other access points thus the 1240AG series and they are working as expected but our new 1260 Series are the issue
Can you post the config for your 1240s. Little confused on your statement about NPS and chnaging the EAP timers. Are you using EAP as your security ?
Post the 1240 config and lets start from there..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Amjad Abdullah
'''snip'''
Error Message
DOT11-TKIP_MIC_FAILURE_REPEATED: Two TKIP Michael MIC failures were detected
within [number] seconds on [interface] interface. The interface will be put on MIC
failure hold state for next [number] seconds
Explanation    Because MIC failures usually indicate an active attack on your network, the interface will be put on hold for the configured time. During this hold time, stations using TKIP ciphers are disassociated and cannot reassociate until the hold time ends. At the end of the hold time, the interface operates normally.
Recommended Action    Michael MIC failures usually indicate an active attack on your network. Search for and remove potential rogue devices from your wireless LAN. If this is a false alarm and the interface should not be on hold this long, use the countermeasure tkip hold-time command to adjust the hold time
'''snip'''
http://cisco.com/en/US/docs/ios/12_4t/wlan/configuration/guide/wlcgerr.html
so, if you insist to use TKIP and not to move to AES, you can try to decrease the tkip holdtimer by thte command:
countermeasure tkip holdtime
by default it is 60 seconds. you can lower it to 0 or a few seconds.
You need to note the cause could also be due an attck going on around. So, you need to look if there is any attack source.
Amjad
below is the config on the 1240s
uilding configuration...
Current configuration : 2508 bytes
version 12.4
no service pad
service password-encryption
hostname xxxx2
enable secret 5 $1$cDdz$2K8EckCSDA6LtLutI5LwS0
aaa new-model
aaa group server radius rad_eap
server 10.10.10.1 auth-port 1645 acct-port 1648
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid ITSWireless
   authentication open eap eap_methods1
   authentication key-management wpa
power inline negotiation prestandard source
username xxxx password 7 032752180500
username xxxx2 privilege 15 password 7 0704314149584B564347
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid ITSWireless
channel 2417
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
dfs band 1 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.10.10.12 255.255.254.0
no ip route-cache
ip default-gateway 10.10.10.26
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.10.10.1 auth-port 1645 acct-port 1648 key 7 095C4F1A0A0E120B2B5D5679
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
Can you send the 1260 config over as well.
After some searching I havent come across anything. Are you on the lastest autonmous code ? Have you opened a ticket with TAC ? Can you move to AES, its a pain the in the rear I know ..
config of the 1260 below
Building configuration...
Current configuration : 2749 bytes
version 12.4
no service pad
hostname xxxxx
logging rate-limit console 9
enable secret 5 $1$uUGZ$cR.8a0qVd8jKWa7J/Yae4/
aaa new-model
server 10.10.10.1 auth-port 1645 acct-port 1646
dot11 syslog
username xxxx password 7 072C285F4D06
username xxxx privilege 15 password 7 046B2B151C2A1F57584B56
bridge irb
no ip address
no ip route-cache
ssid ITSWireless
countermeasure tkip hold-time 1
antenna gain 0
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
bridge-group 1
no ip address
no ip route-cache
antenna gain 0
dfs band 1 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
ip address 10.10.10.3 255.255.254.0
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.10.10.2 255.255.254.0
no ip route-cache
ip http server
snmp-server community defaultCommunity RW
radius-server host 10.10.10.1 auth-port 1645 acct-port 1646 key 7 08116C5D1A12560E43595F
bridge 1 route ip
line con 0
line vty 0 4
end
i havent logged to TAC and my other 1240s AP are working fine, so moving away from standard will be an issue @ the firm, i have changed the  TKIP MIC Failure holdoff time to 1sec and tried disabling it and still connections are dropped.
Face value it looks good. You said you tried disabling it and you still see connect drops ? That should negate the bad MIC and not drop the conenction.
What code is the 1260 on ?
