Wireless AP 1260 issue
thembsmoyo26
We are having challenges with our new access points Cisco 1260, it drops connections after a couple of minutes I get the following errors
"Two TKIP Michael MIC failures were detected within 30 seconds on Dot11Radio0 interface. The interface will be put on MIC failure hold state for next 60 seconds."
"Interface Dot11Radio0, Deauthenticating Station Reason: Invalid MIC
21 Replies 21
these are the messages being generated after disabling TKIP MIC holdoff time
Received TKIP Michael MIC failure report from the station  0024.d75a.9d58 on the packet (TSC=0x0) encrypted and protected by group key.
Interface Dot11Radio0, Deauthenticating Station  0024.d740.8fe8 Reason: Sending station has left the BSS
what do mean by what code is on 1260
well
what about this
CSCti75313     Clients get TKIP MIC from AP3500/1260/3600 due to Raw 802.3 packets
try
switchport mode access
switchport nonegotiate
on the AP radio configuration mode:
countermeasure tkip hold-time 0
Please Make sure to rate correct answers
Cant configure switchport mode access on a AP, countermeasures tkip holdtime is set to 0 already
changed encryption mode to AES-CCM and users are connected and no connections are being dropped, the problem is this is contradicting company global standards on Wireless AP, we have other access point which are working fine with TKIP encryption
please assist in solving this problem without changing encryption mode
what type of NIC is having this issue? is it on the latest drivers avaialble?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
johhoch01
I had this very same problem on two Cisco 1262n access points. The Cisco 1242AG access points did NOT have this issue. I upgraded the IOS from ver. 12.4(25d)JA1 to ver. 15.2(2)JB and my problem went away.
I upgraded the ios to 15.2(2)JB and the AP worked fine and the users connected and no connections were dropped, the problem after a couple of minutes I couldn’t connect to the AP using the web browser and when I tried to ping the AP address it timeout, tried to reboot and nothing changed I couldn’t log onto it using the web browser and users where now failing to authenticate, I tried  to log on using the console cable and all setting were still in place changed the AP's ip address, soon after that I was able to ping the new configured ip address and I was able to connect using the web interface and users were able to connect, when I updated the AP's ip address on the radius server, I started to have problems I wasn’t able to connect to the AP using the web interface and also couldn’t ping it, reboot AP and still couldn’t log on to it and users failed to connect as they were getting authentication failures.
please can you assist
