08-04-2015 02:24 PM - edited 07-05-2021 03:41 AM
Hi All,
I recently purchase a Cisco Aironet 3702i with PoE injector but appears to not be receiving an IP address from what I can tell. I have it plugged into a Nortel 3510-24T switch with VLANs configured. In testing I plugged up to a Cisco switch and everything worked perfectly but when I try with the Nortel switch the AP constantly flashes green. I'm sure I have the VLANS set correctly as Im able to plug my PC to the same port and recieve an IP address.
Does anyone have an Idea on what could be the issue here. This issue have me stomped.
Solved! Go to Solution.
08-05-2015 10:07 AM
As per my understanding you must Enable PoE injector option on WLC.
Further more if your PC is working fine on same port you use to plug your AP and then make sure your PoE injector is working fine or replace it ,because your AP will get power via PoE injector but not your PC via Nortel 3510-24T switch.
Hope that will be helpful
08-05-2015 11:22 AM
Well first try disabling CDP and STP on the port your using for PoE and test.
Let me know whats the result.
08-04-2015 04:04 PM
If you could post AP console output, we can see what's going on.
Rasika
08-05-2015 06:13 AM
Hi Manannalage
See the Log Entries below:
*Mar 1 00:00:16.291: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:16.747: Registering HW DTLS
*Mar 1 00:00:16.755: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:16.807: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:19.123: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:21.627: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:21.739: Loading Power Tables from ram:/Q2.bin. Class = A
*Mar 1 00:00:21.739: record size of 3ss: 1168 read_ptr: 4F6D906
*Mar 1 00:00:26.943: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:26.987: Loading Power Tables from ram:/Q5.bin. Class = A
*Mar 1 00:00:26.987: record size of vht: 2904 read_ptr: 4F6D906
*Mar 1 00:00:27.147: Wait until the stile protocol list is initialized.
*Mar 1 00:00:28.395: Start STILE Activation
*Mar 1 00:00:30.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:31.211: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JBB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 04-May-15 17:26 by prod_rel_team
*Mar 1 00:00:31.211: %SNMP-5-COLDSTART: SNMP agent on host AP-WareHouse-Indoor is undergoing a cold start
*Mar 1 00:00:31.231: No HALO Module. Kill Process
*Mar 1 00:00:31.479: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Mar 1 00:00:32.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
--More--
*Mar 1 00:02:14.203: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewin*Mar 1 00:00:33.351: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:33.503: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:33.503: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:00:34.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:34.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:00:43.387: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:44.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:46.279: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Mar 1 00:00:46.279: DPAA Initialization Complete
*Mar 1 00:00:46.279: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:46.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:48.683: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:49.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:49.715: Currently running a Release Image
*Mar 1 00:00:50.139: Using SHA-2 signed certificate for image signing validation.
*Mar 1 00:00:56.555: APAVC: Succeeded to activate all the STILE protocols.
*Mar 1 00:00:56.555: APAVC: Registering with CFT
*Mar 1 00:00:56.555: APAVC: CFT registration of delete callback succeeded
*Mar 1 00:00:56.555: APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:00:56.555: Pool-ReAtach: paks 42878 radio42270
*Mar 1 00:01:04.087: AP image integrity check PASSED
*Mar 1 00:01:04.167: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
*Mar 1 00:01:04.187: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:05.279: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:05.287: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:06.279: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:06.523: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:07.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:01:14.191: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:01:14.195: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Mar 1 00:01:18.383: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:01:20.383: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:01:21.383: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:03:04.203: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar 1 00:03:54.203: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
08-05-2015 08:22 AM
Mar 1 00:15:31.959: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:16:21.963: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:17:11.967: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
AP84b8.02b6.01c8#
Not in Bound state.
*Mar 1 00:18:01.971: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:18:51.975: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:19:41.979: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:20:31.983: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:21:21.987: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:22:11.991: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
AP84b8.02b6.01c8#
Not in Bound state.
08-05-2015 10:07 AM
08-05-2015 11:01 AM
I've tested the PoE Injector on another switch with the same AP in the same VLAN and it worked fine. Im begining to think that its the Nortel switch thats some how preventing this. Just would hate to replace a whole switch for 1 AP.
08-05-2015 11:22 AM
08-05-2015 04:16 PM
After trial and I managed to get his working by removing the vlan from an STP group on the Nortel switch.
