Wireless Backbone?
jawad1979
Level 4
Level 4
Is it possible to deploy a wireless network with more than 90 APs with no single wire? The throuhput will be cut by half for each repeater, so is there any way to deploy it without any wires linking each AP?
Thanks in advance
tcross3
Level 3
Level 3
You can reduce the interference by using 4 channels instead of 3. Take a look at;
http://www.cirond.com/White_Papers/FourPoint.pdf
I do not see why it would not work if you managed your frequencies and ssids.
Hope this helps
Tom Ross
Network Engineer
Queens College
