wireless basic questions
The_guroo_2
Level 7
Level 7
Gys i have out of box 20 AP 1100 LWAP...and cisco 22XX WLC......i need few information
1- what is option 43 in DHCP once i take the AP out of box shd i config static IP for managment
2- How LWAP reguster to WLC?
Thanks guys
maldehne
In order for the AP to get registered to the WLC it should be able to find the mangement interface ip address of the WLC
, this can be done in many ways:
- AP sends LWAPP discovery request as broadcast on its local subnet . If there is any controller in the same VLAN the controller will send LWAPP discovery response to the AP.
- If the AP is on different VLAN other than the management interface ip address we should find a way to provision the AP with the controller ip address. For example
We can use DHCP option 43 where we define option 43 for the pool from which the AP gets ip address and we populate that option with the ip address of the controller management interface ip address.
Also we might use DNS resolution for CISCO-LWAPP-CONTROLLER.localdomain
Here is a couple of links that should be helpful to you:
http://www.cisco.com/en/US/docs/wireless/technology/controller/deployment/guide/dep.html#wp1050339
For DHCP option 43 configuration:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml
Static commands that you might use to provision the AP with controller ip address:
AP#capwap ap ip address
AP#capwap ap ip default-gateway
AP#capwap ap controller ip address
AP#capwap ap hostname
  (optional)
Please Make sure to rate correct answers
