Wireless bridge question
slappeeee
I have a project where I need to connect two building using a wireless brige.
I cisco specialist told me to purchase two 3500  (AIR-CAP3502P-A-K9) access points and an external antennas.
The problem I have is these access points will need something to control them. If the access points will be in separate buildings will I need a controller on either side of the bridge to get them to work?
What other cisco AP device capable of 300Mps dual band that are autonomous and can bridge between two buildings that are a 50 yards apart?
Stephen Rodriguez
There is an iOS image for the 3500, but why pay the extra for clean air when it won't work in iOS mode?
Go with the 1262 and external antenna.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Steve
HTH,
Steve
Thanks for the quick response.
Can I use the air-ant25137np-r antenna as I was planning on using with the 3500 wap?
That should work
Steve
HTH,
Steve
