wireless bridge using 802.1N technology
nlg-networks123
Visitor
Hope you can help me here folks, I have configured a wireless bridge using 2 x AIR-SAP2602E-E-K9 over a distacne of about 80 metres.
This is working well at speeds up to 54Mb, however I was hoping to reach over 200Mb using 802.1N technology, would appreciate guidance on this.
Attached are the configurations - how do I configure to start using 'N' speeds over the wireless bridge?
Kind regards
Dave Bell
Rasika Nayanajith
Use 5GHz (Radio 1) instead of 2.4GHz (Radio 0) to have better throughput. In that band you can bond two 20MHz channel to give higher throughput.
With the current config since you already have WPA2/AES, no additional config required to enable 802.11n data rates.
Rasika
