Wireless bridging
George.burtz
Community Member
I want to use wireless to bridge a long distance in my plant instead of using fiber. Can I use a 1200 AP to do this or do I need a 1400?
Thanks!
rsahney
Level 2
Level 2
The best thing to use would be a Bridge which can range up to 25 miles, wereas an AP is limited to only a mile.
The 2 options that you can try are br 350 or br 1400.
the first one is still running vxworks wereas 1400 is running IOS.
Keep in mind the kinda setup and the characteristics of the devices and then choose the best.
regards
