Wireless Calculating Tools
utawakevou
Level 7
Level 7
Does Cisco have any free tool for calculating Fresnel Clearance Zone, antenna and cable etc.
If so can someone point it to me so that I can download. Anyway, all my wireless sites are using 350 bridges
towler
Level 2
Level 2
Start here:
__ http://www.cisco.com/go/wireless
and then select "Antennas" from the drop down list under "Products"
and then click on "Technical References" under "Technical Documentation"
and then click on the "Outdoor Bridge Range Calculation Utility"
Or just click here:
__ www.cisco.com/application/vnd.ms-excel/en/us/guest/products/ps458/c1225/ccmigration_09186a00800a912a.xls
Good luck,
Richard
Thank you very much. I have downloaded the excel file
