Wireless Client not authenticating
get2dapsy
Community Member
Can anyone help with possible ideas why Apple MAC client and Desktop using 3Com PCI card migth not authenticate to the WLAN.
Security implemented on the WLAN is WPA2/Enterprise with PEAP.
AP 1140 series
RADIUS server; WIndows NPS
Controller: 4404
Thank you.
George Stefanick
Is this a 802.11 auth issue or radius auth issue? When the client connects look in the GUI under clients. What is the STATE of the client?
This is a Radius auth issue.
Ok, so the client state is 802.1X_REQD when you look ..
Lets start high level:
Have you looked at the fail logs in the radius server? If so what is it reporting
Are you validating certificates on the client end.
How are these clients reporting their domain name to the radius server. Is it consisent like the other devices or different.
